if you cant get stock drop link undone
(which is a VERY common problem) then it can get tricky.
use a ring spanner on the nuts, then get an allen key into the allen socket.
position it so that the allen key is resting against the strut body somewhere so that as youre undoing the nut it cant move, then hit the spanner with a hammer to impact it loose.
thats the easiest way to get them undone and works well for me.
youll want to spray PLENTY of penetrating oil on them before hand.
if you round the allen socket off youll end up needing an angle grinder on there.
