Oil change
Oil change
I have a 93 n/a mr2 and today decided to change the oil and filter, as ive only owned the car for 4 weeks, everything was going fine untill i had to remove the old filter once i had finally located it there was no way i could remove it, as for the position of it i could get my hand around it but no leverage as too smaller area, and as for access from underneath the car no way, so has anyone else had the same problem, if so any ideas on how to get the bloody thing off.
Re: Oil change
www.machinemart.co.uk/shop/product/deta ... hand-tools give this a shot this is what i use on mine
just started my own welding business! fingers crossed it works out
Re: Oil change
Cheers think id better order one
Re: Oil change
ach ,just puncture a hole through it with a screwdriver and use the screwdriver for a bit of leverage
Re: Oil change
You can t as theres no room or leverage.
Re: Oil change
there is room ,i done it on mine take the drivers side rear wheel off and remove the undertray
Re: Oil change
Did that don t work
Re: Oil change
first time i done it i used large plumer style grips
Re: Oil change
mr2 import wrote:hmm you can get to all the screws on the door apart from the front one iirc!! might need a stubby screwdriver to get the ones at the bottom! might be enough for you 2 get in and have a look
Edit* is your door locked or unlocked??
ehh??wrong subject i think ?were you reading about opening a door and replied to an oil change thread excellent
Re: Oil change
lol yeh its been a long day lol sorted now tho
adam
adam
