[Mk2] [Turbo] traction controll
liamdavies
Post by liamdavies »
how do i know wheather ihave traction controll,and if not how? and how hard is it to fit?
also how hard is to fit abs?
ancient mariner
Re: [Mk2] [Turbo] traction controll
Post by ancient mariner »
hi mate,can only have factory fitted traction control if you have abs,as the two go hand in hand.also if you have it fitted you will have two warning lights on the dash and also a swich,to enable you to switch it on and off.hth.paul.
Turbo97
Post by Turbo97 »
where is the switch, cos i have like 3 switches on the panel like underneath my ignition and i dont even know what two of them do!!!!!! :lol:
Grajey
Post by Grajey »
http://www.imoc.co.uk/forums/viewtopic.php?t=115742
and
http://cgi.ebay.co.uk/Racelogic-Launch- ... 240%3A1318
will give you the best system around. IMO
Note; Check with Obladeo first to find out if the launch control button is included with his kit.
HTH
