Drive Shafts all the same with all models??
Are all drive shafts all the same between all models i.e rev1-5, turbo and NA etc which means there all interchangable?
Re: Drive Shafts all the same with all models??
No
- I cant say for sure on N/A's but rev 1 turbo drive shafts are different.
- they didnt come with an lsd as standard
- I believe you could have it as an option but the drive shafts are still different from later models.
ok so more to the point will a rev2 turbo with LSD drive shaft fit a rev3 turbo with LSD?
IronMike wrote:ok so more to the point will a rev2 turbo with LSD drive shaft fit a rev3 turbo with LSD?
if they are both abs outers or both non abs then yes, other wise no
can anyone else confirm if a rev2 turbo drive shaft with abs will fit a rev3 turbo without abs?
Jay's right
- you can't mix ABS and non ABS driveshafts
/ hubs
- ISTR that the wheel hubs are different.
