Has anyone got any ideas how I can get them out?
Pug_crew wrote:Thanks for the responses.![]()
Couldn't work out how to make a connector so ended up removing the rubber the fits around the piston and then using a couple of very old(blunt) wood chisles managed to lever the piston up using the channel the rubber came out of.
Took some time and a grazed knuckle so I wish I'd had read your message dopiaza before I started this morning!
