Air con not engageing
RobCrezz
Post by RobCrezz »
Not sure when it last worked to be honest, havent really used it since I have had the car. Checked the 2 fuses but both are fine. The A/C light comes on, but theres no sound of it cutting it and temp doesnt change.
Any ideas?
Ed
Re: Air con not engageing
Post by Ed »
Have you checked the belt. I had the same problem and the air con belt had snapped.
Understeer is when you hit the wall with the front of your car and oversteer is when you hit the wall with the rear of your car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Baker
Post by Baker »
possible are:
compressor has bought the farm
snapped belt.
system needs regassing.
take it into anywhere that does aircon servicing and they will know for sure.
RobCrezz
Post by RobCrezz »
Baker wrote:possible are:
snapped belt.
Went to kwikfit the other day incase it was something simple, but they just gurned at me and said it needs to go to a specialist :lol:
Olly P
Post by Olly P »
Mine does the same and in my case, it needs regassing.
toxo
Post by toxo »
Yep, that's what mine did before I got it regassed at kwikfit... if it's a rev3 as your profile suggests then it's the same as any other modern car's aircon and they can regas it! In fact, the machines they use will actively refuse to regas a car that's got the old style gas in it.
jmachling
Post by jmachling »
Easy check - there's a sight glass in the frunk on the right hand side behind the plastic shroud. It's a cube of aluminium with a round window in the top.
If you can see fluid in there then it's just low. No fluid is probably a more serious leak somewhere, most likely the condenser rad at the front which has no protection from stones.
si2040
Post by si2040 »
hi, more details on this please as I've never seen a block with liquid before... Mine has a leak!
MR2 Night Fox
jmachling
Post by jmachling »
http://www.mr2-tech.com/bgb/mechanical/ ... system.htm
Click on 'Refridgeration System' then scroll down to AC-12 :thumleft:
toxo
Post by toxo »
Inspection is covered in the BGB - there's a small metal cube near one of the valves (L I think) which is in the frunk on the right hand side, near the power steering controllers. It has a circular 'sight glass' in the top of it.
Edit: Damn, you beat me to it!
Leakie Tbar
Post by Leakie Tbar »
Screw driver in the ac union press the nipple very quickly down and release psssssttttt you have gas!!! nothing u got a leak or need a recharge if you where up in the Northeast I would do for you.
Sits back and waits for someone to say that's illegal
