Do I need an adaptor for my head unit?
do i need some kind of a special connecter for the stereo coz there isnt a stereo yet and i had a cheap 1 i was going to use for time being but its completly different connecter that goes to back of stereo
Stereo connection
Audio lead for fitting of an aftermarket stereo to an active system
http://cgi.ebay.co.uk/MR2-PC9-411-Audio ... dZViewItem
Re: Do I need an adaptor for my head unit?
how do you know if you have an active system or not?
My car did nto come with a stereo and only has one connector in the dash ones I have seen on ebay seem ot have 2 connectors?
if you have 1 or 2 subs behind either yours or the passenger seat then you have an active system, you will then need to identify what connection is required
(14 or 15 pin lead)
Also.
remember that the subs are in the cubby boxes.
Not just generally sat there
mks2005 wrote:how do you know if you have an active system or not?
mines the same,only one white plug into a standard toyota cassette head unit but all the converter plugs are twin???
Put up picture of your plug it will either be 14pin or 15pin I can send you a new one for
£16 delivered.
Your new stereo has to have two pairs of RCA outputs if its got one I can supply you with splitter leads or hi to low level adaptors like this.
