Eibach Springs
Mav122
Eibach Springs
Post by Mav122 »
Was thinking of freshning up my suspension soon. Anyone got an opinion on eibach springs? I was thinking eibach springs on Koni dampers as I know this combo works well on a few cars. Anyone have an opinion or other ideas?
IanClements
Re: Eibach Springs
Post by IanClements »
I have that setup on mine, I find the Eibachs are a little soft at the front end with sloppy steering compared to stock springs. They're OK but you have to keep the Koni's on a firm setting if you fancy a blast.
Mav122
Re: Eibach Springs
Post by Mav122 »
Any opinions on pi springs?
omracing
Re: Eibach Springs
Post by omracing »
You could always try Apex springs ?
Red MR2 Mk1a - Rose SOLD
Blue MR2 SC conversion 180 bhp - Lightning
Paff
Re: Eibach Springs
Post by Paff »
I like PI springs, will be using them on my V6 and track car, they are being run on my mates SC, I've fitted them to another SC. I also sold a set to a local lad and he's happy with them.
Mav122
Re: Eibach Springs
Post by Mav122 »
Didn't know Apex did a set for the mk1... hmm Anyone tried them? what about H&R spings as well?
Mav122
Re: Eibach Springs
Post by Mav122 »
Does anyone other than Koni and KYB do dampers for the mk1 that don't cost into the 4 figure numbers?
SuperRedMR2
Re: Eibach Springs
Post by SuperRedMR2 »
thought you were not going to spend anymore money eh?
Tokico do dampers I think
omracing
Re: Eibach Springs
Post by omracing »
Mav122 wrote:Didn't know Apex did a set for the mk1... hmm Anyone tried them? what about H&R spings as well?
Yes they normally range between £100 - £120 per set.
MartG
Re: Eibach Springs
Post by MartG »
Yep - often supplied with the Koni suspension kit
Mav122
Re: Eibach Springs
Post by Mav122 »
SuperRedMR2 wrote:thought you were not going to spend anymore money eh?
On the engine I meant by that. Part from an ally flywheel it's bout time that stock brakes were replaced for better ones and suspension given a seeing to :D.
Mav122
Re: Eibach Springs
Post by Mav122 »
Anyone tried tokico dampers? Any opinions. Just want a wide range of knowledge and opinions on the different types before parting with a lot of hard earned cash is all. :thumleft:
User avatar
Lauren
Re: Eibach Springs
Post by Lauren »
Mav122 wrote:Anyone tried tokico dampers? Any opinions. Just want a wide range of knowledge and opinions on the different types before parting with a lot of hard earned cash is all. :thumleft:
I'd get Koni's. You get what you pay for. Tokico are a bit budget and jap dampers of this ilk are a bit under par IMO.
Mav122
Re: Eibach Springs
Post by Mav122 »
sounds like koni it is then. koni or h&r springs though. I've heard real good things about h&r.
SuperRedMR2
Re: Eibach Springs
Koni dont do dampers for the mk1a do they?
Nige_B
Re: Eibach Springs
Post by Nige_B »
Where is the best place to buy Konis? I can't seem to find anywhere :?
Mav122
Re: Eibach Springs
Post by Mav122 »
Koni themselves list mr2 a and b dampers for the rear on their site as do fensport. fensport also list front ones but don't mention year so i assume they fit both
omracing
Re: Eibach Springs
Post by omracing »
As far as I was aware Koni only do the shocks for the Mk1b. I bought a kit for my Mka and they didn't fit, so I changed to Mk1b rear struts and they fit fine now :thumleft:
coverco
Re: Eibach Springs
Post by coverco »
If you want Konis why not buy my spare car, you will have to drill some holes for the top mounts but with a spare car you will have all the bits.
http://www.imoc.co.uk/forums/viewtopic.php?t=113547
It would work out (nearly) cheaper than buying the Koni kit and you get a free car for spares :thumleft:
User avatar
Lauren
Re: Eibach Springs
Post by Lauren »
SuperRedMR2 wrote:Koni dont do dampers for the mk1a do they?
I had a set for a MK1a on my MK1a funnily enough. I swopped my used set from a mK1b for the MK1a ones, so they weren't bought recently as such, unless Koni have stopped making the MK1a ones? IIRC it's only the rears that are different.
