[Mk2] [Turbo] Worth switching air filter?
dave_f
Post by dave_f »
Hi guys
Currently have a rev3 turbo with all the bolt on mods, greddy i/c, ebc, decat and blitz exhaust, and blitz access ecu along with cooler plugs.
Its got an apexi panel filter on at the moment and i was just wondering whether it would be worth changing over to a cone type filter such as the apexi power intake. Would there be any performance increase from doing this?
Also whats the maximum boost a should run on this, i assume its 1.2bar...
Moo
Re: [Mk2] [Turbo] Worth switching air filter?
Post by Moo »
You'd only get a minimal power increase by switching to a cone filter, maybe 2hp if you're lucky. The Apexi power intake doesn't half sound nice though so worth it for the sound alone :wink:
1.2bar on your mods is about as high as I would go.
platmatt8
Post by platmatt8 »
Might up bhp a little bit the main thing i noticed when putting on a cone filter was how rev the rev counter became.
Quigonjay
Post by Quigonjay »
personally i would rather keep your current set up
yes, you may gain a couple of horse power and lots more noise but i would rather have cooler air and less noise myself
redmr89
Post by redmr89 »
its worth it for the noise alone.
Baker
Post by Baker »
You 'may' lose power. as mentioned, the air will be cooler with your current setup. the good thing about the apexi though is they've got a heat shroud which should nullify the heat soak somewhat.
but the noise is a bonus.
2tonemr2
Post by 2tonemr2 »
as said sound awsome iv had KnN and hks mushroom on mine and the apexi jus sounds so much better and is one of very few kits that have the hugger heatsheild
Quigonjay
Post by Quigonjay »
Baker wrote:You 'may' lose power. as mentioned, the air will be cooler with your current setup. the good thing about the apexi though is they've got a heat shroud which should nullify the heat soak somewhat.
its a rain shield not a heat shield
KrisMoyse
Post by KrisMoyse »
Obviously I know I fall differently into this catagory because I'm a N/A guy but I've gone for a carbon encased cone induction kit.
All the perks of a straight through pipe (no resonators) fed from the side vent giving it an awesome noise when accelerating but quiet when not and also the bonus of keeping the air cool until it gets to the engine.
Well worth the money in my opinion and what I'd choose over and over again :thumleft:
Baker
Post by Baker »
doubles up as a heat shield though doesnt it?
tarmac terrorist
Post by tarmac terrorist »
go for the arc airbox looks the nuts ,sounds the nuts & keeps air cool,i have an apexi in my garage that i took off cos it was pulling in hot air
