My engine bay cooling fan light has come on this afternoon after replacing the battery.
Can anyone help?
Pete
That lamp, the voltmeter not being up at the two-thirds mark when engine running nicely and your battery died a few days back? It's most probably a charging problemPete wrote:i did wonder about the alternator.Having just fitted a good battery, the voltmeter is only at the mid point on the scale
(was more at 3/4 last week).
un1eash wrote:Cant remember of the top of my head so will post 2nite when i check my haynes unless someone else does before hand.
What issues exactly are you having?
Pete wrote:OK, another update!
All had been well, but now when I get high up the rev range(5500+), the battery and engine cooling fan light flash on again
They stay on unless I drop the revs.
I was wondering if they have fitted the wrong alternator i.e one with less output, I know there are a couple of different ones available for the MK1- does this sound like the case? How would I check?
Thanks again.
