can someone please tell me the differences between rev2 and rev 3 n/a's?
ami right in thinking that rev 2's are 158bhp and rev 3's are 173bhp in standard form?
what actually gives this difference in power?
rev2/rev3 na whats the difference?
Re: rev2/rev3 na whats the difference?
yep your right inlet manifold is different for a start obvious straight away when looking at both, thay also have different down pipes and manifolds i think and also air filter system is different im sure someone will give better explanation
interesting information, been wondering the differences between the two models power increase wise, are the manifolds/ downpipes bolt on, i assume they are?
Obviously the fuel system is probably altered but im sure bolting the later spec manifolds on would slightly increase the power?
Differences are through out the engine I believe, head, cams, CR etc
Its a much more eager reving engine at the top of the range.
Got a TechTom ECU on my rev3 n/a and it flies round to 8100rpm happily
