Trying to get some advice from people running upwards of 350bhp on which turbo to go for. Ideally i'd like one that can be externally gated but if theres a big difference would consider others.
I'm guessing that you should get a turbo thats rated quite a big higher than your power goal (i.e. 400bhp turbo for 350bhp etc.) for every day reliability.
Post away
[Mk2] [Turbo] What turbo do you run?
Re: [Mk2] [Turbo] What turbo do you run?
if you havent seen it before then its quite interesting
Tasty wrote:T88 500+ ggs
Shut it you I wish!
I'd recommend the GT30 series all day long. Ive got the GT3076r. Cracking turbo. Good spool and great power.
sard 3470moj
Olly.Dent wrote:Im fitting this kit within the month.
http://www.imoc.co.uk/forums/viewtopic.php?t=112615
That looks great, scream pipe too!
How much are they...dare I ask? Also, it claims up to 30psi no problem, wouldn't that be a bit overkill for 350bhp and slow as spooling up?
HKS T04R/Z - 500+
Loads of lag, loads of power ! Just keep it between 4500 and 8500 rpm for a good time !
There not on sale as yet but will be within the next couple of months.
I and a couple of others were picked to be the UK testers so i will keep everyone updated with what happens, dyno sheets etc.
For prices the best man to ask is Baktash at EMSPowered.
Here's abit more about it...
http://www.imoc.co.uk/forums/viewtopic.php?t=112547
As you can see you will be able to pick turbo trim size depending on what power and spool rate you want.
JJ wrote:HKS T04R/Z - 500+
Damn! If thats what I need i've just gone and bought the wrong bloody clutch then!
Courier coming for it today !! Just hope I havent packaged the Fidanza fly by accident to you !!
JJ wrote:Damn! If thats what I need i've just gone and bought the wrong bloody clutch then!
You haven't have you? Legend
Nope !!
JJ wrote:You haven't have you? Legend
Nope !!
lmao
theres a page from the mr2oc that says about what turbo and mods and how much power but i cant find it if someone else could post it up
Thats a great link, cheers! Looks like the TD06 and T3/T4 kits are the popular ones then. How much do these go for then? Recommended sites?
I've noticed that those kits are only rated for around 350bhp, is this right? I was planning on going for a circa 500hp rated turbo and running it on low boost as I want 100% (or as near as I can get) so dont want to be stressing everything fully.
