ST185 Sock for Rev2 CC set up
StevieL
Post by StevieL »
Does anyone have the part number for this or know where i can get it?
Need it quite urgent!
Stevie
Marf
Re: ST185 Sock for Rev2 CC set up
Post by Marf »
Theres a guy breaking an ST185 engine in Parts for Sale, he may have one?
murf
Post by murf »
I should have it somewhere
StevieL
Post by StevieL »
murf wrote:I should have it somewhere
Nice one, it would be much appriciated. :D
Means i can get this CC set up finished this weekend \:D/
toxo
Post by toxo »
Part no for ST185 sock is 17861-88381 if that helps.
StevieL
Post by StevieL »
Nice one,
Thanks mate :mrgreen:
StevieL
Post by StevieL »
toxo wrote:Part no for ST185 sock is 17861-88381 if that helps.
Is it not 17861-88382 as the part ending 1 is a bit small???
bolton
Post by bolton »
ive just modified a st205 sock to fit my rev2!! you elongate (sp) the holes and the use allen key bolts in it!!
StevieL
Post by StevieL »
Well ive ordered the part ending 2 so when i pick my CC core up from my fabricators on Friday, so im going to pop into the Toyota garage to test the 2 parts, if not i'll use the ST205 Sock i already have and just modify it.
toxo
Post by toxo »
I was working from this page:
http://www.toyodiy.com/parts/p_J_1991_T ... _1703.html
Which, if you click on the sock numbered 17861 gives you a part number ending in 1...
Apologies if it's wrong :oops:
StevieL
Post by StevieL »
Its cool Toxo,
i'll update this thread with what i find out on Friday :thumleft:
bolton
Post by bolton »
whys your core at the fabricators??
StevieL
Post by StevieL »
bolton wrote:whys your core at the fabricators??
Having some sensor plugs welding into it :thumleft:
toxo
Post by toxo »
Nice idea! You'll need to give us a demonstration when you get it back ;)
