Rather than spending the earth on a full set up, I'm considering the options of fitting just a bigger set of discs to the car, but using the stock calipers.
What are peoples opinons on this?
Thanks,
Ant
JJ wrote:I'm sure Chris Isles got some Jag XKR's on the front of his!!
cantfindausername wrote:I've PM'd Jap Spec to see if they offer it as a kit or can supply details about the caliper adapter.![]()
Johnny, Does the RX8 front definately fit on the rear? I've tried to find the size for the center hole etc, but have come up blank for now.![]()
Do you think the RX8 would be a better option than the supra rear then?
Big Brake kit
720 mk2+3
Some Specs:
-ROTORS, 324mm diameter, 30mm thick
(12.76" x
.1.18") curved vane directional, cross drilled.
-CALIPERS, Wilwood forged Superlite four piston
(4.5 lbs compared to stock caliper around 9 lbs each)
-PADS, Wilwood BP10
'Smart Pads'
-FLEX HOSES: Stainless steel braided Teflon hoses
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
