My car is a mr2 turbo revision 1, Heres a couple of my elecrical problems.
When i turn the key to ingnition on position the rad fans come on and my power steering cuts out.
If i pull the connector off the battery for 5/10 seconds then re attach, all electrics come back on line.
Thing is when i checked all my fuses I found that, if i pull the 7.5 amp ecu-b fuse it sorts the rad fans they stay off and my power steering comes back on, but if i turn the key to start nothing happens.
Hope some one can help as i am absolutely baffled by this.
