Hi, im planning on changing my clutch/gearbox in the next week and thought i should change the driveshaft oil seals at the same time.
Just wanted to know whether this is the correct part number
90311-30006, and i take it its the same for both sides and they are installed just by hand???
cheers
The seal you quote IIRC, is an internal seal in the transaxle casing.
Driveshaft oil seals are different for turbo and N/A, and N/S and O/S.
Need to know what car you have....
