[Mk2] [Turbo] Tyres
WAKEY MR2
[Mk2] [Turbo] Tyres
Post by WAKEY MR2 »
Getting some new rims 17s , and want to know if ( 215 40 17 ) on front and ( 235 40 17 ) gonna be ok on my car as its low , bout 30 mm drop i think ?
Also thinkin of goin for the Toyo T1 - R s , anygood ?
Leon.
Re: [Mk2] [Turbo] Tyres
Post by Leon. »
Should be fine with a 30mm drop, slightly depends on the offset of the wheels...? Also, how wide are they?
T1-Rs are pretty good with those kind of profiles yeh :thumleft:
blue2
Post by blue2 »
I found them too soft, i went with goodyear f1's last longer and just as good imo :D
Leon.
Post by Leon. »
blue2 wrote:I found them too soft, i went with goodyear f1's last longer and just as good imo :D
On 17s? When you say soft do you mean sidewall or compound? With enough air in them they're considered pretty good tyres.
I prefer F1's myself too, little bit more expensive... However, the new assymetric model is supposed to be sh1te, and that's coming from Tony at WIM.
Stealthy
Post by Stealthy »
I had the asymmetric F1s on the back of my old 325 coupe and thought they were pretty good, but I can't compare them to the original eagles as I've never owned a set.
I also am getting some 17s and going to run Toyo T1-Rs (205/40R17) on the front and the PXT4s (225/45R17) on the back, heard good things about them :)
blue2
Post by blue2 »
I meant the compound. With mine they didnt last as long as other tyres. They are very grippy, possibly more so than the f1's but with the extra grip comes extra wear. It depends on what you are after, the toyos will possibly grip better, but having said that you probably wont notice it unless you are on a trackday or really pushing it. I only went for the f1s for cost. Not sure about the asymetric model whats this? :D
Leon.
Post by Leon. »
They are discontinuing the existing F1s and replacing with a new assymetric model which has poor performance, or so I am reliably informed.
I was recommended to go with T1-Rs now because of this. I do so few miles that I don't need to worry for a while...
