longshot I know
Reversed the car off my drive and found a solitary nut:
Don't know what it's off, found directly under my car. I have put a 5p coin next to it for size.
Thanks for any suggestions. I'm pretty worried about what is under my car without a nut
Thanks for any help.
found a nut on my driveway anyone know what it could be off?
Re: found a nut on my driveway anyone know what it could be off?
Looks like a shoulder nut to me mate.
Oh yeah, thats a nut not a bolt.
Dont worry about it mate a shoulder nut is a mechanics term for a pointless extra, you will be there forever trying to find were thats missing
It's the one that holds the chassis together, and stops your brakes and steering from working
Actually, it looks like the nut on the front ARB bushes
cheers fellas.
Johnny if it was an ARB bolt wouldn't I notice a banging etc when driving?
Car is sound on the road.
I will have a look at the ARB bushes on the rear, the nut could have fallen off and rolled into the middle underneath of the car.
Possibly, depends how loud your stereo or exhaust are
I'd check it though
I'd check it though
Yeah, rear nuts look the same.
JohnnyC wrote:Possibly, depends how loud your stereo or exhaust are
I'd check it though
lol, I'll check it tomorrow.
Is there just one nut either side where the bushes are at the rear?
Are the front nuts the same? One either side of the bush?
Thanks Johnny
Other thing as well, my car has a 22mm TRD antiroll bar at the rear and has black rubber bushes.
I didn't think you could get stock bushes for the TRD bars, only poly bushes
Just been out to the car in the rain.
Both rear ARB bush clamp bolts are there, the fronts I doubt I'll be able to see without jacking the car up.
RedMR² wrote:Is there just one nut either side where the bushes are at the rear?
The nuts on the front & rear look the same, but they're different part numbers so probably slightly different.
There's only one nut per bush (plus a bolt holding the other end of the bracket).
JohnnyC wrote:RedMR² wrote:Is there just one nut either side where the bushes are at the rear?
If I jack the car up and have a look at the bushes at the front and they're both present what the hell could it be?
- IMOC Moderator
looks just like one of tiny ones that holds the heat shields on.
cheers for the suggestions, I'll look at the possibilities suggested
anymore ideas?
anymore ideas?
Two similar nuts on where the front strut rod meets the lower arm - can't remember size though.
And OEM Toyota droplink nuts - although these only tend to come off with an angle grinder
have you had any work done on your car lately? if you have check what was done. my mate has his breaks done and ten mins down the road his caliper fell off. ( halfords )
maybe off the exhaust manifold studs?
From an undertray as it's quite small...?
I think undertray seems most likely. I'll jack the car up this weekend and have a scan
