Standard Suspension and DV Query
dazz_ni45
Post by dazz_ni45 »
First of all Happy New Year to everyone...
Picked up a rev 2 a month ago and had it out for the first time today getting a few bits and pieces done.
First of all I had the wheels off to get rebalanced as I had a vibration at 70mph and the shocks are black with yellow writing that says Bilstein Toyota. Is this standard suspension or an upgrade?
Secondly when coming off boost and coming to a road end or lights when I come off the throttle. brake and apply the clutch when I come to a stop the revs dip to about 200rpm and the cars stalls (not all the time). I have done a bit of reading about rev 2's and BOV's and have come to the conclusion that this could be the cause.
When revving the car in neutral the BOV goes off, is this normal?
I got a bags of bits of pieces with the car and I think the original recirc BOV is in there. Does anyone have a picture of it fitted or a re-fitting guide and I would like to try it back on.
Many thanks
cantfindausername
Re: Standard Suspension and DV Query
Post by cantfindausername »
Pic of a stock bov.
Should be easy enough to re fit.
***RIP Car13 ***
*** Now in an Evo ***
Tasty
Post by Tasty »
The bov will operate in neutral if you rev hard enough for turbo to cut in . #-o
513BHP at the hubs
BenF
Premium Member
Post by BenF »
dazz_ni45 wrote:Secondly when coming off boost and coming to a road end or lights when I come off the throttle. brake and apply the clutch when I come to a stop the revs dip to about 200rpm and the cars stalls (not all the time). I have done a bit of reading about rev 2's and BOV's and have come to the conclusion that this could be the cause
Yep, sounds like your Rev2 is more fussy than others and will actually stall. Some BOV's have conversion kits to allow them to vent back into the intake - sounds like what you need.
Razor04
Post by Razor04 »
Tasty wrote:The bov will operate in neutral if you rev hard enough for turbo to cut in . #-o
The BOV will also go off in reverse if anyone's got the bottle to try it lol :lol: :lol: :lol:
Mr2'less
dazz_ni45
Post by dazz_ni45 »
Does anyone know if Blitz does the conversion kit?
Razor04
Post by Razor04 »
i've got the blitz bov and would also like to know if there's a recirc kit available for it? i've had a look around couldnt find anything
Mr2'less
cantfindausername
I had a blitz BoV, but made my own recirc kit. Worked a treat :thumleft:
***RIP Car13 ***
dazz_ni45
Post by dazz_ni45 »
cantfindausername
Dont see why not. :thumleft:
***RIP Car13 ***
