whitline anti roll bar
stew
Post by stew »
hi all bought a set of whithe line bars on ebay and wondered how to set the front one it has three different settings just wondered what was the best setting the car is a sc mk1 with konis and standerd springs thanks for your help stew
Mk1Chris
Re: whitline anti roll bar
Post by Mk1Chris »
I would tell you, but you outbid me :(
Only joking, i'm afraid I dont know.
Smallport 4AGTE
cartledge_uk
Post by cartledge_uk »
stew wrote:hi all bought a set of whithe line bars on ebay and wondered how to set the front one it has three different settings just wondered what was the best setting the car is a sc mk1 with konis and standerd springs thanks for your help stew
personally I agree with chris :wink:
But then I have a set in my gaage anyway.
put them on, drive it, then change it, and see which one you prefer, there is no otehr way
Paff
Post by Paff »
As tthe 2 guys above, noone can tell you whats best, everyone has a personal preference, the only way to tell what works for you is to try all the settings.
kaiowas
Post by kaiowas »
I'm even more annoyed than Chris and Tim as I forked out for a brand new set a couple of weeks ago then saw these on eBay :(
Not fitted mine yet though so I can't give any advice either.
IanClements
Post by IanClements »
I WILL tell you but you outbid me!
I've found with ARB's (at least on the front with different bush types) that what setting to use depends mainly on rim size and what type of ground you're driving on.
If you set them too stiff then your car will lose grip over rougher surfaces and bumps but the trade off is keeping the car level, it depends whether that kind of thing bothers you. I found that with 16 inch rims my car was skittish in this way and I had to go back to standard ARB but with 15's it's much improved no doubt because the tyre takes more of the bump.
Big ARB's are best for the track IMO but having said that the stock rear bar is really tiny.
Karl_T
Post by Karl_T »
I've got a set of these, adjustable front (and rear I think), best mod I ever made to the car. Both mine are set at the mid point at the moment, which is where I started out and to be honest I've never played with em, the car just feels OK so I haven't fiddled.
Certainly not too stiff for the road. They don't affect the ride anything like as much a stiff springs, but sooo much better through roundabouts. :D
15" rims, standard shocks and springs.
Karl_T
Red ones go faster......
IanClements
Out of interest what sizes are they?
crazybrightman
Post by crazybrightman »
ha looks like everyone was bidding on them! not sure on a setting but the closer to the bar the stiffer the setting. id set the rear a little stiffer for oversteer biased handling or the front a little stiffer for more under steer prone handling. somewhere in the middle for both would in theory give the best balance. best bet is to go drive and see what settings work best for you.
4agte on the way
tonigmr2
Post by tonigmr2 »
If you're fitting both and you haven't had adjustables on before my major recommendation is you set them both the same. :) I've done the hard front/soft rear and vice versa thing and the car is never as settled as if they are the same.
I've tried different settings racing but I think the best road set up would be the middle point - it is a good compromise for different conditions. (Racing people tend to put them on hardest in the dry and softer for wet conditions, hence unless you are keen to continually fiddle I'd go with the mid-point, unless you do a track day in which case you could adjust as necessary).
T
stew
whiteline anti rollbars
Post by stew »
thanks guys for all the advice as usual use are all very helpful. the car runs on 15 inh wheels i think i will try the mid range and see how it goes sorry i outbid use guys but blame the wife i was at work she was doing the bidding. thought they where a bargain \:D/
Karl_T
Post by Karl_T »
Well I've just checked my IMOC garage, as I suspected I'd have stuck the details in there and it says 20mm front and 16mm rear.Too long ago to actually rememeber, but if I typed it up there that's probably right.
Karl_T
