[Mk2] [Turbo] help fitting new turbo engine back in
RED TYSON
Post by RED TYSON »
imtrying to fit my rev2 turbo engine back in but im having problems with the passanger side engine mount(the 1 under the air filter) every time i lift the engine up it turns on the p1$$ why????? ive got the drivers side in (the 2 bolt 1) is there a how to do this because its starting to p**S me OFF
help please ada
Quigonjay
Re: [Mk2] [Turbo] help fitting new turbo engine back in
Post by Quigonjay »
you are lifting it up with hoist or jacking up on pallet?
how exactly is it not lining up? you are getting the bolt holes high enough but they are going either forward or backwards of their intended position?
you got a big crow bar or someone to help you?
BLZ-8027
Post by BLZ-8027 »
I had the same issue with mine just persevere with it
I had a jack under the front of the engine by the bulkhead to twist the engine over whilst i lifted it ,i think its just the angle the engine lifts at
I think i also fitted it to the engine first :-k
cantfindausername
Post by cantfindausername »
If you've got a hoist, support the engine, get a chain or what ever you're using to lift with and wrap that round the gearbox and lift it from there.
It really shouldn't be that much of a problem either way. Just give it some damn good wiggling and lifting and it will eventually slot into place.
***RIP Car13 ***
*** Now in an Evo ***
RED TYSON
Post by RED TYSON »
got it sorted now.gave it a kick lol
cantfindausername
A good shouting at normally helps too. :thumleft:
***RIP Car13 ***
