[Mk2] [Turbo] 1992 revision 2 gts smoking when ticking over,any ideas?
My 1992 revision 2 gts has started to smoke when its ticking over,its fine when im driving it with no smoke either on or off boost,it only when its not on the move,its done 55,000 miles and as far as i know it hasnt had a turbo rebuild yet,do you think the turbo seals are leaking or could it be a valve seal perhaps?any advice would be greatly appriciated
Re: [Mk2] [Turbo] 1992 revision 2 gts smoking when ticking over,any ideas?
id hazzard a guess at it being the turbo
Turbo seal.
Same thing happened to mine at about 95,000 miles.
oh thats ok,not the end of the world then,thanks for the info
Nah not at all.
I did a 3500 european road trip the week after mine went, then a few santa pod trips and day to day stuff too
