Hi,
Can any of you tell me what the brace highlighted in the picture is called?
Is it replaceable? If so where can I get a couple as the ones on my G-Limited a rotten with a capital R. I guess they're not essential or safety critical as it passed it's MOT okay.
Many thanks.
as said above £16 from toyota think its called a chassis brace as said common to break i xxxx myself when i found mine completely rusted away, 20 min job to fit undo two 10mm bolts that hold plastic undertray then you can slide your hand in to undo the bolt at each end, when i get round to getting a new welder i wish to make solid ones of these as thay are hollow and badly designed water gets inside and thay rust from the inside out its a tube with squashed ends with two holes drilled in it crap
Thanks for the advice guys. There is a Toyota garage just round the corner from my work so I'll maybe just pop in there and order a couple.
Just out of interest does anyone know if uprated/aftermarket braces are available? I think they're available for the Mk3 but haven't come across any for the Mk2.
Thanks again,
Steve.
not that i know of. they would have to be as light as the originals but not prone to disappering into an unkown vortex lmao. to be fair mine were 16 yr old and without the rear underbelly for god knows how long
