Judging from the oil filter position, the BGB guide is based on a rev 1
Now I've just stumbled across a guide to mk2 turbos on the net
My question is: does anyone know what the compression ratios should be for a 94 onwards turbo engine? as this paragraph indicates they should be lower than the 164psi target on the rev 1
Also, could someone just confirm my thinking that compression readings should be lower on a stone cold engine than an engine that's warmed up?
Ian
