Ive resistance checked the Throttle pos sensor, afm and isc valve.
I noticed however if i unplugged the lambda it wouldnt do the hunting thing and idled at 1000 rpm consistently
The afm has been modded 2 clicks but idle was fine in the past.
Ive removed the dump valve out the loop also to eliminate that.
This car is seriously getting my back up and after trawling the net for clues im still none the wiser.
