oil type/grade?
bobbyh
oil type/grade?
Post by bobbyh »
sorry for the tedious newbie quezzies!
monkeymax
Re: oil type/grade?
Post by monkeymax »
LimeyMk1
Re: oil type/grade?
Post by LimeyMk1 »
10W 40 Semi synth is ok for the 4AGE. Most peeps use Magnatec but I've found Mobil Super S is pretty damn good. :thumleft:
crazybrightman
Re: oil type/grade?
Post by crazybrightman »
i vote for the same 10w40 but millers oils :thumleft:
4agte on the way
System-G
Re: oil type/grade?
Post by System-G »
Limeymk1 wrote:10W 40 Semi synth is ok for the 4AGE. Most peeps use Magnatec but I've found Mobil Super S is pretty damn good. :thumleft:
I use either Magnatec or Mobil SuperS as well now.
I went through a spate where I used Halfords own 10W40 as I was changing oil every 2000 - 3000 miles. But following a couple of big end failures. I use nothing but them two now :thumleft:
BTW this tool can also be very handy:
http://www.imoc.co.uk/forums/search.php
Welcome to the forums :thumleft:
un1eash
Re: oil type/grade?
Post by un1eash »
This tool courtesy of jinxy can also be very handy...
BIGBOBO
Re: oil type/grade?
Post by BIGBOBO »
un1eash wrote:This tool courtesy of jinxy can also be very handy...
Oh god, why didn't I think of that? I spill it every time and it always leaks past the rubber of the cables into the area with spark plugs. A total mess to clean up. ](*,)
lazaros1
Re: oil type/grade?
Post by lazaros1 »
Yeah or you could just use a funnel! :thumleft:
Paff
Re: oil type/grade?
Post by Paff »
I've actually got a funnel that is in 2 parts, it unscrews and the thread on the funnel cone is exactly the same as the thread in a 4A. didn't buy it for that reason just found out by accident later.
LimeyMk1
Re: oil type/grade?
Post by LimeyMk1 »
Paff wrote:I've actually got a funnel that is in 2 parts, it unscrews and the thread on the funnel cone is exactly the same as the thread in a 4A. didn't buy it for that reason just found out by accident later.
Halfords ones are like that. :thumleft:
BenF
Premium Member
Re: oil type/grade?
Post by BenF »
FWIW, my Mk1 was run previosly by Nick Challoner who used 0W40 Mobil 1 in it. Pulling it apart to replace the HG the inside was in top condition :
I've been using 5W40 Mobil1 which I pick up in France when doing a day trip for ~£25 for 4 litres.
