My understanding is that you can lose compression in 4 directions.
1
- into the crank case via blown rings/piston skirt
2
- into the ports via cracked/damaged valves
3
- into the coolant system via the head gasket
4
- into the head via damaged combustion chamber
- I would say there are others, but it depends how anal you want the list to be.
As for the car still running, that depends how bad the compression loss is I guess.
What ever the cause, its not a good thing.
