I've been looking for a low-mileage blue t-bar
http://cgi.ebay.co.uk/Toyota-Mr2-mk1-T- ... .m14.l1318
Looks ok from the photo's, although I'm not keen on the wheels
Thanks in advance,
Gary.
System-G wrote:The owner is known on a few forums.It sounds like a genuine car and from what I have seen posted on another forum, it's worth it.
Just check it& drive it as you would any other MR2 really.
Although be prepared for the extra power from the added Fensport Pulley
& ABV mod
GaryR wrote:System-G wrote:The owner is known on a few forums.It sounds like a genuine car and from what I have seen posted on another forum, it's worth it.
& ABV mod
Thanks for the information, can you point me to the other forum?
Also, what's a ABV mod,(roughly) how much would the insurance be and where would be a good place to get a quote from?
Cheers,
Gary.
un1eash wrote:http://www.mr2supercharger.com/ABVmods.html
It basically allows more boost as the standard system will only allow 8-10psi.
GaryR wrote:Are SC suppose to have the same teardrop alloys that the NA has?
Lauren wrote:GaryR wrote:Are SC suppose to have the same teardrop alloys that the NA has?
Yes, although they are diamond polished.
System-G wrote:Lauren wrote:GaryR wrote:Are SC suppose to have the same teardrop alloys that the NA has?
I thought it was only the SE's that were diamond polished?
GaryR wrote:
Ah, so the teardrops from my NA that I spent 2 weeks restoring will look a bit odd.![]()
I'm still doing the'man-maths' to figure out if I can afford it.
In terms of insurance quote, what do I say when they ask
'Does it have any mods?' I'm guessing that the larger pulley and ABV will need to be decleared, anything else I should mention
Cheers,
Gary.
andyj wrote:Yes, I almost bid on this.![]()
Bidding ended Saturday morning with a closing bid of
£2250.
The seller, Simon, offered for me to view the car on Friday.![]()
Though I didn't he obviously has nothing to hide.
His description is quite detailed and he seems very pleasant to deal with.
Yes, I was bit put off by the wheels but it's apparently got solid rear arches, ABV mod and Camry idler pulley- an intersting spec.
In short, if goes for that sort of money again it's a bargain.
New door, respray bonnet.
fix window and fix couple of monor things and for
£3K someone will have a brilliant SC.
I'm trying to sell another MR2 so slightly wrong time for me.
