I have also tried running new vac lines and from different locations, aircon idle up, map sensor and
nothing has worked apart from when i rebuilt my blitz valve, cleaned and oiled it, it worked about 4 times and stopped again.
any suggestions why this is happening?????
the valve is getting vac and boost so i dont see why this is happening, please help!!!!!
everything else seems fine, boost gauge shows normal vac and boost, so i'm pretty sure theres no leaks.
the actual vac tubing is new aswell.
any ideas???? im sure the compressor surge isnt good for the lil ceramic turbo
cheers
__________________
