coverco wrote:Peter have you ever studied metallurgy?
Yes thank you.
coverco wrote:The correct engineering solution for a drop link is to have one continuous piece of rod with a ball joint at each end, which is how they come from the manufacturer, shortening the metal rod is a bodge I am afraid.
I disagree.
I note you have not criticised my other two examples of shortening by cutting and shutting, namely propshafts and driveshafts.
coverco wrote:As to the industrial revolution well you are wrong there as well..
Welding was used of course but it was at lower temperatures than modern welding techniques and so the metallurgical changes were not as extreme.
Errrr, why does that make me wrong?
In any case, i've said my part.
