Pistols MR2 stories... MK1 and 2zz MK3
pistol pete
Re: Pistols MR2 stories... Race car and Project car..
Post by pistol pete »
Well i have had a few days out in the car now.. getting to know it..
It is great, really enjoying it, learning it. but cannot use it anywhere near its potential on the road.. well not safely anyway, thats why i sprint now :)
But safe to say it is crazy quick
So i had started a little list in my head of things that needed doing
I took the nose and bonnet off to make work easier
First off is the exhaust could do with re-packing.. luckily it is a repackable exhaust.
i got the exhaust off and found it actually has a cat in it.. i am going to leave it there, help keep the noise down and much easier at MOT time
here it is stripped down, new packing order should be with me Thursday
So that is all sat there waiting..
Next up was a small oil leak.. coming from the dry sump pump outlet.. it was only tiny..
found one of the allen bolts was loose, then found the thread stripped.
So taken out, re-tapped and refitted,, all nice and tight, i suspect may still leak very slightly on the pipe inlet, but i will have to wait and see. hopefully its fully sorted, If not then its a pump out, exhaust off job
Next up was the flat floor, as the sump sits lower that the chassis and sticks out i wanted to get the flat floor on asap,to help protect the sump, but a load of the riv-nuts were spinning or just come out
so with a drill and new riv nut gun and a bit of time later.. we have a fully flat floor
here you can see the flood now under the engine rather than just ground
of course this will help me if i am losing oil as to how much
Also changed the oil at the same time, now go the joys of trying to make sure dry sump is at the correct level which on a bike engine you can only do when its running, so that will have to wait untill the exhaust is back on
In preperation for racing.. of course it "may" rain, known to happen in the uk every now and again
So a romper suit to keep me dry was purchased.. if it does rain i'll make sure i get a picture of me and Ben together (he has the same suit)
Lastly is tomorrow or wednesday i am going to be fitting the track wheels/tires.. this will mean some alterations to the front wings.. which is good as i am not happy with how they sit, a bit too close to the tire for my liking
So much so one of the screws has made a nice indent all the way round on one tyre
adjusting them for the race tires then just leaving them with a bigger gap for the road tires seems the likely way forward..
blogsy
Post by blogsy »
Good stuff mate. with regards to your exhaust, I think you'll find with it being a Q it gets mot'd like a car from 1976. Does the serial no start SAB.
pistol pete
blogsy wrote:Good stuff mate. with regards to your exhaust, I think you'll find with it being a Q it gets mot'd like a car from 1976. Does the serial no start SAB.
Thanks.. I am pretty sure you are correct but I suspect its only 100 cell cat and it will help keep the house f down
Magic Beans
Post by Magic Beans »
Correct. It's basically:
Does it stop
Does it start
Is anything terrible coming out of it
Is anything falling off it
Do the bright bits light up
That's pretty much it :)
MikeyB571
Post by MikeyB571 »
That looks lovely, you need to get that out on the track and embarrass some mr2's :)
pistol pete
MikeyB571 wrote:That looks lovely, you need to get that out on the track and embarrass some mr2's :)
Thankyou mate.
First outing is the 3rd of april :thumleft: :thumleft:
MikeyB571
Post by MikeyB571 »
Thankyou mate.
Cool, let us know where and I might join you. I'm off to Oulton park on the 12th March and defo doing another late March or April.
pistol pete
Grr wrote is out once stupid pad decided to refresh...
Try again
Went about fitting the track wheels today.. the orignals i am running for road use a are yokohama wet tyres 185 60 13 front 205 60 13 rears.. new ones for trsck use are avon zzr softs 205 50 13 all round
Got the rears on first without issue.. the are close to the deffuser but its clear
Next up was the fronts.. i knew these would take a bit of time as wanted to increase the gap between wheel and arch..
Also due to the width the wheel would not go on due to the arch upright...
Pics of how it looked once arches were off
So i wanted the front arches to look right with either the road wheels or track wheels..
I managed to only get one side done today.. there was a lot of bending to get the wheel on.. the getting the attchment point in the right place with the right gap..
Then to get the arch to sit central had to cut to carbon to get the arch to sit over far enough.. and then re drill the fixing holes
Both wheel now sit really nice and central.. huge difference between them..
I got to get some carbon patches to cover the old holes.. but this is race a race car now
Here is how the standard wheels now fit yes whole car needs a clean
See where its had a trim up
See how different mounting points are now
Road vs track
And how the track wheels sit
Now just cover the old holes and tidy up a bit will look perfect
To do the otherside tomorrow
shane34
Premium Member
Post by shane34 »
How do you think the laptimes will be compared to the mr2
Looking good!
pistol pete
shane34 wrote:How do you think the laptimes will be compared to the mr2
Looking good!
I am not sure yet be great to see.. i expect it a lot lot quicker... completly different class of car
In other news finished off the odd jobs today
The exhaust wadding arrived to that got fitted and re installed.. as it heats i should expand fill it and hence make it quieter.. so will give it a few runs and do a db reading and report back.. sounds good though
Next up was to finish the front arch wheel fitting.. pretty much exactly the same as i did on the other side again fits perfect..
I am though as soon as i can afford it will be getting new wider arches and new arch carrier brackets. Current brackets have been bent about so much in their life they are starting to not look so great or line up straight.. but neither are expensive be about 200 to sort the whole thing
But these are on and working for now so do the job..
This arch sits out slightly too much.. but only really notices in the picture... its doing its job till new ones come
I then rolled it out fired it up and made sure all the oil levels were good on the dry sump sytem once it had warmed up as oil has been changed
Then got the nose back on and some pics of the the flat floor/splitter and other bits
Took for a drive with daisy
I love those tyres.. after driving these the yokos are really showing their age... and it drove great sounded better and no more front arch rubbing noises yay..
It really is silly quick too
Then to finish the day i gave it was wash and a dry and tucked it back to bed...
Very chuffed..
I am thinking at some point ill need to re wrap it as the wrap is cracked in some places.. which opens a whole world of oppotunities
pistol pete
well loading up tonight.. going up to see the TSS guys racing sat..
then first round in the busa on sunday..
CANNOT wait!!!!!
really looking forward to it..fingers crossed touch wood everything goes smoothly, although it never does
At least i am learning the new car on a known track..
Kepp eye on the facebook page or my facebook page for on the day updates if interested :)
MikeyB571
Post by MikeyB571 »
Nice, good luck.
pistol pete
Fastest run of the day.. will edit it later..
https://youtu.be/1wPTxowZQWQ
pistol pete
Not been updated for a long time..
but It is now zombie stickered up, and went for round 2 at blyton for the javelin sprint series..
feel a lot more at home with the car now..
Had a lot of fun, and smashed the time i was aiming for on first run out..
Ended the day with 3rd in class (1st&2nd had about 50-70hp up on me) but ill get them next time..
couple of vids for you
Sorry for the smudge that was a fly from earlier
https://www.youtube.com/watch?v=4mPpFG_z4_o
https://www.youtube.com/watch?v=Iuwjeh8rA1w
https://www.youtube.com/watch?v=8jq_2XxRPTk
pistol pete
No pictures really.. just an update,..
Had a issue while out the other day. The charging loom decided to melt..
Somehow managed to get it home.. new rectifier and re pwired now running okay.
But could not test due to the cycle wings snapping the bracket.
New wings and brwckets purchased.. done much neater job than last ones we sorta bent all in wrong angles.. i have a got a proper bender at work so all at right angles pqinted and ready to fit tomorrow..
Ill sort some pics tomorrow
Magic Beans
When a Mule becomes a Zombie, only good things can result 8)
pistol pete
Magic Beans wrote:When a Mule becomes a Zombie, only good things can result 8)
Inddedy :)
As promised
blyton park trophy.. very chuffed with this
Looking into wiring issue..
the problem is found
rectifier was not in air flow so bracket made, remounted new one and plug re wired
My old front wings and brackets as said before have been moved around soo much there were well knackers..
here they are to give you an idea
also i have had problems with them rubbing on hard cornering on track..
So new wings and brackets purchased. these i wanted set just right with nice bends on etc..
painted and properly bent
correct holes sliced in to keep strength
fitting on the car..
Took Andy Ayres on here out for a test run... he said its a hooligan :)
ran well, stronger above 7k, so suspect the wiring/rectifier has been on way out for a while
ayresyboy
Post by ayresyboy »
i did indeed get a shotgun ride in it. oh my gosh. i will just call round to Pete instead of going to alton towers! i need to sit in it going round a track.
JD
Post by JD »
Sad sad times :(
Onto the next project :)
