androo007 wrote:That's a badass looking 2- good job
Cheers buddy.
JLW wrote:Cars looking great pal, the rear diffuser really works with those spats also!
gnzyza wrote:looks ace![]()
you wont encounter many two's running a diffuser either.
craig wrote:Forgot to add the results of fitting the TRD low temp thermostat compared with the factory Toyota thermostat.
Both results from cruising home on the M1 from Barnsley(45 miles):
TRD low temp thermostat:
Water temp: 70 degrees
Oil temp: 90 degrees.
Perfect.Temps would obviously rise with load/boost.
Now compared to the data for the stock thermostat:
Stock Toyota thermostat:
Water temp: 82 degrees
Oil temp: 100-110 degrees.
C35Rob wrote:
so your engine is now running too cool while cruising![]()
C35Rob wrote:I was more commenting on the coolant temp side of things,the PFC has a water temp correction table, two in fact, one for vac and one for boost
- basically a curve of fuel enrichment vs water temp, if it hasn't been altered from the base apexi settings
(I'm yet to see a map that has been, including one of Ryan G's) then anything under 80 deg will richen the mixture
- the
% of enrichment is dependent on the temp obviously, but if you're consistently running under 80deg then you're over fuelling, all of the time.
markstevieandmads wrote:Did u not get the air con system completely renewed when the car was built?
If so, what was the reason to get rid of a working system?
craig wrote:Straight through another MOT.![]()
matt-mr2 wrote:Nice work Craig
