kev8611 wrote:ashley wrote:kev8611 wrote:ok i get the point.il keep my opinion to myself.
mr2rich.sorry to have caused any confusion to you.
after all.
peter and co are the specialists on here so anyone elses points are invalid
opinions are fine, but you have to be open to challenge when throwing around statistics like that mate..
.all meant in good humour, apologies if I offended
ok so in other words.whats the chances of going and buying a set of 86mm CP's and a standard blocks measurments being bang on for required clearances on the spec sheet down to the last ten thou?
Based on your data: 0%
Based on my data: 75%
Real answer.
Only real way to know is to strip the block in front of you and inspect and measure it
