Brakes Lock too easily
BarronMR
Re: Brakes Lock too easily
Post by BarronMR »
Correct me if im wrong but, 'locking up' in simple terms is the tyre road interface breaking down. Therefore as long as your brakes can cause the forces required to exceed the limits of grip available in this relationship then you can 'lock up' the wheels.
All below assumes a well maintained fully operational setup.
If all other aspects remain the same, by changing the brake caliper system (ignoring pad material and disk size) all your doing is changing the feel of the brakes, ie bite point, travel etc... The advantage of a bigger system is the way it deals with heat, ie being able to produce the same force after repeated braking by dissipating the heat better.
So in my mind, unless you can cook your brakes while in intended use (road/track) or the pedal feel does suit you, then probably you can leave the caliper alone. If you want to improve the car's resistance to lockup, look at better tyres.
On converted car's the brakes will have to work harder due to the added mass. But unless you exceed the weight of what toyota deemed the mk1 setup good enough for, ie a supercharger, t-bar with all the trimmings (1200+kgs?) then you should be ok for a road car. Obviously things have changed since toyota designed this system, with better tyre compounds and tyre designs. These will cause heat to build quicker in the braking system than intially designed, as will higher average speeds the car might be braking from.
I think the reason anyone notices a differance is probably due to the bias changing.
I've driven a stock setup and a Front:st185, Rear:mk2 mr2 setup. I believe the modified setup also has some master cylinder mod too (there was a purple anodized bit when I took it apart?). Both work fine, the mk1 setup is a good road setup, can lock wheels when required force is applied. And the modified setup is the same but can make many repeated stops from ***mph without fading but also has less travel and feels better under my foot. :thumleft:
Sorry for essay. :-#
Tellso
Post by Tellso »
Cheers guys, seemed to open up a can of worms here :-k
Someone very kindly put a write up on how to replace the brakes with Celica units. Im sure i read it once before but could anyone point me in the right direction as i cannot seem to find it again? And does this write up also include the rear brake upgrade option?
Cheers again all for all your info :thumleft:
PW@Woodsport
Post by PW@Woodsport »
We discovered the Celica brake upgrade, to be honest there's no need for a write up, just remove the whole Mk1 caliper and bolt the complete st165 twin pot on to the Mk1 hub, it works with the stock Mk1b disc.
aw11rally
Post by aw11rally »
Makes sense to fit braided lines while you've got the calipers off.
Tellso
Post by Tellso »
Was looking at that actually but wandered would i still get the braided lines for a MK1 MR2? Or are the same for both anyway?
Gad
Location: Castle Donington, home of fast cars and strange festivals...
Post by Gad »
Yep, Goodridge are the most common ones I've come across, HEL also do them, you can find them on most of the part sites that supply MK1s, fensport, camskill and the like.
Personally I found I couldn't actually get my standard brake lines off so I think I'm going to have to get a garage to do mine.
Jim-SR
Post by Jim-SR »
the Goodridge hoses used to be on eBay pretty cheap as well. get the stainless ones, they cost a little more but last a lot better.
