I managed to strip the bulk of the engine today, now that I know I have plenum clearance and have 3 confirmed options for intercooling the thing.
The only two problems I found were erosion of the Titanium Nitrate coating on a couple of tappet buckets.
I COULD get them re coated, but the people that do it are slow, and don't like little batches, so I will just buy a few more buckets ready done from the USA.
The other problem only came to light when I removed the crank, which is fully polished and really should be on our lounge table, rather than inside an old Toyota 4 pot! The Yanks love BS and certainly had someone's trousers down polishing this thing, it looks chromed.
This engine had run perfectly, with perfect oil pressure and no apparent issues, and as you can see from the photos below all the main caps LOOKED perfect, but on undoing the
(ARP) bolts on number 2 main journal the cap fell into 2 pieces
I am intending to fit steel billet main caps anyway, and won't be using this block in the turbo build, so it's no big deal, but I was surprised how well a 10,000 RPM
+ engine had held together with only 4 fully functioning main caps.
I have decided to buy yet more rods, and have pistons with 20 mm pins made at 8.75 to 1 compression ratio.
I will also run 3/8 inch rod bolts, rather than the very small, and expensive high spec 5/16 bolts in the current Carrillos.
The turbo pistons may well be a bit heavier due to thicker crowns and thicker rings
(I will go up from the current 1mm rings to 1.2 mm ones).
So now it's time to get the 4A-GZE block cleaned, honed to round and parallel on the biggest current bore, some billet main caps fitted, line bored and honed, the head deck ground, and some custom pistons ordered from CP or JE.
I can also spec and order the new rods, too.
Finally I need to order the cams, which will almost certainly end up being a custom grind on billets.
This is the part of the project I really enjoy, as things start to come together a bit.
It's a good job I did decide on pursuing this project, if I'd been tempted to run it in N/A format any longer I suspect the bottom end would have let go
Photos of a genuine, and slightly broken,
Formula Atlantic spec 4A-GE engine in bits at
http://www.newbury-house.com/atlantic/atlantic.html
Cheers.
