Like Lauren, I've been lucky enough to own both and ITR and various models of MR2
(both MkI/MkII).
I also am of the opinion that even though the MR2 is a great car, the ITR is without doubt, more of a drivers car.
Feedback, throttle response and handling are
far
superior to that of the MR2.
However, I now drive an MR2 again as I see it, in MkII guise at least, as more of an all rounder in terms of every day drivability.
stiggy wrote:However, as I've been saying all along
- and this is the root cause of why ITR's aren't as quick on the road as on track
- the extra power the competition has over an ITR makes all the difference when you have to slow down.
Perhaps you could explain this a in a little more detail.
I was under the impression that ANY car would be quicker on the track, purely becaue of the conditions.
Less traffic, controlled environment, etc.
stiggy wrote:Having now driven an ITR, if you're gonna rev it to 7k chances are you aint gonna stop till it gets close to 9!
That does make sense, but only to those that are not mechanically sympathetic.
I moved back to an MR2 purely because of that fact.
I'm fully aware that the magnificent Honda B18C motor is more than capable of revving to well over 9000 rpm quite reliably, but my head isn't, so the car went.
My V6 MR2 makes the around the same amount of peak power as the ITR, but makes a lot more torque at a vastly lower level in the rev range
(2200 rpm).
It wouldn't stand a chance around a track against an ITR though, not even with Lauren at the wheel.
EarL.
