Noob turbo build
Re: Noob turbo build
deleted not needed*
- IMOC Moderator
KO racing is referring to USDM Rev2.
Their ecus are mapped for crap quality fuel.
Just take the plunge and go with rev3 management.
No point messing about trying to make 300bhp with 440s.
aghhh your right i dont know why i keep looking at everything else!
i take it there will be a guide somewhere for the pin outs to help me adapt the rev 2 loom to rev 3 ecu?
should imagine il need a spot of help with fitting the chargecooler, im going to guess its not a straight fit and il need to make up some of my own fittings and piping?
is the gt4 chargecooler onto mr2 a common enough thing?
im still undecided with turbos! i really want a garrett t3 or even the gt28 you suggested but im not savvy with turbo's and alot say their designed to run from 350 to xyz power.
if im sitting between 250-300 will it be an issue?
cost of a garrett new against a 2nd hand ct20b is a no brainer to me.
will i need a st205 ecu from a celica to run the chargecooler?
- IMOC Moderator
No just use an mr2 ecu.
The st205 ecu just has the pump control which isn't needed.
If you come across one you could use it but you'll have a check engine light unless you wire in the pump control.
Gt4 chargecooler is a very popular mod.
Nobody bothers with the ecu though.
T3
(gt3071/76) is completely overkill.
Gt28 will spool well.
It will cost over
£1000 for the turbo alone
(providing it's genuine) then you'll need a manifold adapter
(or t2 manifold) and a downpipe.
Downpipe will need made to fit.
Easiest option by a long way is fitting a CT20
T3
to get 300bhp
Metal HG
Rev 3 management and fuelling
CT20b
Either GT4 charge cooler or an uprated intercooler with decent fan
1,2bar boost.
AFR gauge to keep an eye on everything
Been looking at this myself and also commented on fb.
Metal HG
CT20b
1,2bar boost.
sheppy wrote:No just use an mr2 ecu.The st205 ecu just has the pump control which isn't needed.
T3(gt3071/76) is completely overkill.
It will cost over
Iv spent the day looking more and more into the gt4 charge cooler, iv also
Just need to find out what else I need! Ahh I see, so just need to wire in a switch that will run off I dunno a temp sensor to kick the pump when it's hot or??
Just realised the
Also just want to add you've been s great help so far sheppy.
markstevieandmads wrote:to get 300bhp
Metal HG
CT20b
1,2bar boost.
Exactly that mark, could you tag me in your comment so I can pay attention to who you are and which comments are yours, iv had so many different people chime in I can't keep up!
- IMOC Moderator
You'll get a genuine garrett from owen developments.
.I've mixed reviews on their customer service.
Along with that you'll need a t2
(unless they can do a t3 flanged housing) adapter and you'll need to get a custom downpipe made, oh and oil/water lines.
I would wire your CC pump to the ignition so it's on all the time.
The charge temp can never be too cold.
Righteo, il decide on turbo once iv got the engine back
, parts in and built up, picking up cc potentially this weekend, maybe next, just need injectors then il worry about fcd, controller and gauges once turbo depletes my entire budget.
](./images/smilies/eusa_wall.gif)
- IMOC Moderator
You won't need a FCD with rev3 management.
Fuel cut is 19psi which is more than you need.
Kiefer wrote:Righteo, il decide on turbo once iv got the engine back, parts in and built up, picking up cc potentially this weekend, maybe next, just need injectors then il worry about fcd, controller and gauges once turbo depletes my entire budget.
The ATS GT28RS Stealth Kit would be my suggestion based on what you've written.
So you don't need to uprate the fuel pump for 300bhp?
sheppy wrote:You won't need a FCD with rev3 management.Fuel cut is 19psi which is more than you need.
oh cushti one less expense!
Nic wrote:Kiefer wrote:Righteo, il decide on turbo once iv got the engine back, parts in and built up, picking up cc potentially this weekend, maybe next, just need injectors then il worry about fcd, controller and gauges once turbo depletes my entire budget.
The ATS GT28RS Stealth Kit would be my suggestion based on what you've written.http://www.atsracing.net/Parts/Index/GT28RS
looks perfect! but
do get a free downpipe though.
tiff_lee wrote:So you don't need to uprate the fuel pump for 300bhp?
apparently not tiff_lee
Wideband o2 gauge will save your engine
if you didnt list it
add one bud
Edit
, ps.
water
/ meth 50/50 too
would not heart
Edit
2mad wrote:Wideband o2 gauge will save your engine.
add one bud
Edit, ps.
water
/ meth 50/50 too
would not heart
soooo
wideband 02 gauge
st 205 cc kit
turbo of some description
boost controller
rev 3 injectors
afr gauge
and if i get time a 50/50 water meth kit? iv never looked into it, is it just for cooling? iv heard of methanol injection as well?
Water/meth is a bit overkill for 300bhp.
It gives you a lot of anti det protection allowing you to run more advanced timing, etc.
under boost but is another thing to make sure is kept topped up to prevent your engine going pop.
Would also need an EMS to allow it to be remapped to make use of the setup.
archangel wrote:Water/meth is a bit overkill for 300bhp.It gives you a lot of anti det protection allowing you to run more advanced timing, etc.
Water/meth 50/50 gave me loads of extra performance 25hp easy
