Are the nipples on all Revs the same, ie 8mm?
IMR2T wrote:
Ordered stainless steel banjos,
stuMR2eye wrote:Not doubting your wisdom or experience Bob but from the videos I previously posted can you explain how the handbrake'self-adjusts'?
The conclusion reached by the author of those videos(although the English isn't great) is that the handbrake does not
'self-adjust' by anything other than very fine movement as nothing inside the caliper rotates.
The threaded shaft is on a spring so returns.
The handbrake function is a simple pin on a cam that lifts the shaft
& piston together.
http://sandbag82.blog.me/220261759217
Having recently stripped several calipers a down to the handbrake mechanism I cannot see any ongoing self adjusting mechanism in the caliper.
This has bugged me for a while as I like to understand exactly how the calipers work.I've been searching for a definitive logical answer.
Since the piston merely rotates up
& down the threaded shaft winding it in or out will not re-set anything that I can see.
stuMR2eye wrote:I wouldn't.The threads don't need to seal its just the end of the bleed screw that seals.
Ptfe tape I've found means I can't get the bleed screws tight enough.
Edit: You can use a bit of grease around the threads, only when you are bleeding, if you want but it shouldn't be necessary.I do sometimes when using the vacuum bleeder.
How are you going to fit them? Do you have stock rubber hoses?
The hand brake is self-adjusting, it should come up about 4 to 6 clicks, if it is any tighter the self-adjusting will not work.
With the foot pedal pressed hard downkeep working the hand brake and it will adjust up, you will also feel the foot brake is better after too as it takes the free play out of the pads.
stuMR2eye wrote:Just had a go with a spare rear caliper.Couldn't replicate the handbrake lever adjustment by hand.
Perhaps it's different when working in conjunction with pumping the pedal.
The cam does have a sort of jumping movement with more travel.
But with air(simulating brake fluid) the piston comes out to meet the pads
(block of wood in this case) and stays out to take up the slack.
So something must be rotating inside and suggests that it's the pumping up of the pedal that adjusts the piston.
The mechanism inside is clearly more complex than thought by some.
This gets more confusing! Setting the piston a few degrees winding out or 180+ made no difference in my test.In fact not winding it out at all seemed to make no difference.
The piston still comes out with pressure and stays out.
So many posts and theories online about how these things work.Every forum has a different opinion.
Some people seem to get lucky setting up their brakes/calipers whilst others struggle.
One for Mythbusters maybe!
Anyway back to the OP's initial problem.Got to be air in the system as originally stated.
My bleed screws showed up today
(less than 24 hours after ordering).
Minor annoyance being that are 7mm.
Once air is out the Pistons can be pumped out more effectively.
Then all should be good.
Hi Bob, Im assuming theres another complication ahead of me..
.hence why your asking how am I going to fit them?
I do have stock rubber hoses, why do you ask?
LOVING the handbrake adjustment insight, keep tips like that coming![]()
The banjos come as part of the hose, they cannot be fitted afterwards.
With stainless hoses some use stainless banjo ends but have to be crimped onto the hose, reusable hose ends are an MOT fail.
I get you now, yeah just meant the bolt that secures the banjo to the caliper.
