I've got a Rev1, when I got it the pedal was soft and traveled pretty low.
I just fitted Rev2 Front calipers, pads and discs.
My Rev1 Rear discs are grooved and due needing changed, the pads are low aswell but not enough to fail an mot.
During the bleeding the travel is 1.5-2" and then gets firm and Im happy
I've topped up the levels in the large reservoir attached to the master cylinder and also the smaller one to the right(which I'm assuming is an overflow or a clutch reservoir).
What's causung the larger pedal travel on starting the car
Cheers guys!
