Happy man, idle rough obviously as so may things fiddled but I can't let her run for more then 30secs as I've got to put coolant in now
Thanks everyone for suggestions, off to have a chat with a man about some work now!!
killerferret666 wrote:Started up straight away
slipping clutch wrote:killerferret666 wrote:Started up straight away
would just about sum it up I guess.
Happy days.
MartinF wrote:Good to hear it's sorted![]()
May want to get a timing light on it and just check the distributor is lined up correctly.
slipping clutch wrote:MartinF wrote:Good to hear it's sorted![]()
I agree- however as the diagnostic port isn't in the loom any more what can be done to replicate the te1 to e1 bridge out?
( Its going to be the next question for sure I think
RST wrote:Are the 1991 wiring manuals still on-line, I have them electronicsomewhere
and printed out but unable to post up.
The password for them on-line used to be
"harvey".
Did the colours change significantly between revisions-I know the 1991 manuals helped me a good few times and way better than nothing!!!!!
Perhaps as well, might not be a bad idea if you can get a second hand loom part with the connector and cover, or wire up a cpl of test ports plus a lamp
-great post from peter to read CEL flashes without a cluster IMO.
You can read so much off the stock ECU it makes it so much easier.
Maybe thinking too much and purely for my own curiosity but in kit cars without the cluster but a stock ECU, how do you stop a CEL without feedback to the ECU from the speedo once the car is moving-or do you just do it with the aftermarket gauge?
Or just ignore it?
.useless comment but I was going to say you might be totally out on timing and check the marks.
Sounded a bit like I had on a different car once after I had the head
-off and forgot to account for the tension in the cam belt as it was tensioned
(plus somehow I was a tooth or two out).
