[Mk2] [Turbo] Oil temp sensor location - not sandwich plate or sump
GreddyMR2
Re: [Mk2] [Turbo] Oil temp sensor location - not sandwich plate or sump
Post by GreddyMR2 »
But sump lug is quite low, near the ground. I'm afraid it could be damaged over bumps or with a stone or something.
And about a pressure sensor. Is it bad if I put it in a sandwitch plate?
Peter Gidden
Post by Peter Gidden »
GreddyMR2 wrote:And about a pressure sensor. Is it bad if I put it in a sandwitch plate?
It is not bad. But there is an argument that suggests it is better to measure oil pressure at the top of the engine, furthest away from the pump.
This makes it easy:
http://www.ebay.co.uk/itm/MR2-STARLET-S ... 23230a369c
shinny
Post by shinny »
GreddyMR2 wrote:But sump lug is quite low, near the ground. I'm afraid it could be damaged over bumps or with a stone or something.
Plenty of people run sensors in there :thumleft:
GreddyMR2
Post by GreddyMR2 »
I know that you in UK have a good roads, but not in Lithuania :lol:
But as I am planning that my 2 will be only for track and weekends, maybe it's a good idea, thanks.
Loque
Post by Loque »
GreddyMR2 wrote:...I know that you in UK have a good roads
Bahahahaahahaha...
shinny
Post by shinny »
Bahahahaahahaha...
They're better than most others I've driven on, bar France and Germany. Certainly better than Italy, USA and Malaysia
Adam86
Premium Member
Post by Adam86 »
Alot better than Belgium!!
GreddyMR2
Post by GreddyMR2 »
You should see the roads in Ukraine...
Here: http://www.youtube.com/watch?v=xkfGab09_xo
And that's the main road and that's true, I saw it and driven in one of those roads.
