Lauren wrote:Seriously, buy the Toyota ones, fit them and forget about them.![]()
Not just that, you can never undo them properly, so if they need to be removed to get the strut out then easiest way is an angry grinder
Alan.
phaeton wrote:
Not just that, you can never undo them properly, so if they need to be removed to get the strut out then easiest way is an angry grinder& replace with
£15 ones, instead of fighting for 4 hours with gold plated ones.
Alan..
dylbie wrote:Ulysess, I'm definitely interested in how you did yours with the brass sleeve.My whole supsension needs replacing as I've got a feeling that, after 145,000miles, it's still original and fairly worn! So far I've got the springs, dampers and nuts and bolts.
Now I just need drop links, bushes and, most importantly, motivation!
kaiowas wrote:PW@Woodsport wrote:Seriously Lauren that's the worst advice ever, they are£180 a pair and will fail eventually.
My£20 focus ones last just as long.
£180 a pair? Really? TCB sell genuine Toyota ones for
£40 each.
mr2mk1chick wrote:kaiowas wrote:PW@Woodsport wrote:Seriously Lauren that's the worst advice ever, they are£180 a pair and will fail eventually.
£40 each.
this seems to be a resonable solution- same as 2 sets of cheapos but no welding and hopefully the reliability people are after
Outside make but the quality is excellent equal to Toyota
£40 each.
they arnt genuine toyota anymore
still good though![]()
