I don't think I've ever seen any manifolds for the 4age, but then most mr2 owners choose to swap or use forced induction rather than modify the 4age.
Your best bet would be to try the corolla forums, they seem more into the 4age tuning.
As MartG said toyota probably did a good job from the offset.
But as your motor is beyond what most would consider light tuning and past what toyota designed this manifold for.
You could look at some of the later more powerful 4age's, who knows maybe the later 20v exhaust mani flows better.
Last resort would be a custom fabricated manifold.
But be careful to use a performance engine specialist, n/a engines are tempermental to changed to exhaust manifolds.
They must either calculated accurately as to what lengths of tubing are required and when they merge or use a trial and error method, to make full use of the scavenging effect.
