benedwards64 wrote:Thank you!
I have to say it all looks a bit
'Heath Robinson' but I'm willing to give it a shot if both you and Firestick have had success.
Let me just confirm what I've worked out from the photos
- all the pictures of the pipework are what you have removed, so the air flows from the intake, straight through the trunk and to the filter
- yes?
Also, what would you think of modifying a cone filter to sit in the trunk in place of the airbox?
Well, after Dr.
Smith screwed up the main thruster gyros, it was the only way I was going to get the Jupiter back to earth!
All I can say, is that it has made a huge difference with how mine runs.
If I only had some MKIa cams in it I'd be almost perfectly happy with it.
Yes, the pipe work pictured is what I removed.
So you now have air coming out of the holes, on the air intake piping, and from the normal intake piping outlet.
The air will run both directly across the trunk and also around the back of the tail light trim piece, etc.
Also remember not to reinstall the trim pieces that go over these two areas, because unless you modify them they will definitely impede airflow and put you back at step 1
(I've tried it).
I do hope at some point down the road, however, to place some very neatly spaced holes, in these trim pieces, and reinstall them in order to hide the giblets.
Currently, I think the amount of air that can be drawn into the engine is now only limited by the size of the piping that leads from the filter to the throttle and the intake pipe opening, where it angles off from the passenger side engine vent.
As I believe the latter opening is at least as big as the other one, then there is nothing more we can really do.
The original obstacle was that god awful pipe work behind the tail light trim and deciding how, after removing it, to further unobstruct the air flow from the passenger side to the drivers side.
I had to
"Robinson" the air intake piping and the air filter box because their intake and outlet pipes pretty much extend back behind that trim piece and the air flow was still being mainly directed behind it and was therefore impeded by it, especially when the trunk was loaded.
The only piece that looks really hacked, when all is put back together, is the intake piping.
That will be solved when I cut slots in the next one, instead of drilling holes.
The filter box alterations are not even really noticeable.
As a reminder, remember that the intake piping, as a whole, needs to stay there in order to funnel any incoming water to the drain pipe just behind the antenna.
Certainly a cone filter can be used, but again you have to consider how much, or little, surface area it has.
It would have to be a rather large one to exceed that of the stock filter.
And unless you just have to have something that people will think is a bit more cool looking I would not even consider it as it would take up a lot of space in the trunk, and any time you start loading stuff youd have to try and keep it away from the filter.
With this setup that is never an issue.
I also don't think that virtually any more air can be supplied now, as I think this make up has pretty much reached the limit of what can be drawn in.
I have also run it temporarily without a filter and not noticed any real difference.
Now that I have the photo thing pretty much solved, when I get some more time, I'll take pics of all the different filters I have, and measure their surface areas.
In fact, I'll try and do one last critique of each of the filters, now that my car is running at its peak with the new alternator on it.
