[Mk2] [Turbo] JDM Turbos?
They look like cheap replicas! What are they Like?
Re: [Mk2] [Turbo] JDM Turbos?
llenrub wrote:They look like cheap replicas! What are they Like?
What the devil are you talking about man? Please be a little more specific.
Simple question......what are JDM turbos like?
llenrub wrote:Simple question......what are JDM turbos like?
All turbos are JDM. There was was never a UK model.
I thought you of all people would have known that Llenrub...
Are you talking about the cheap turbochargers(i.e. the part, not the car) that are often for sale on eBay?
LOL @ jims picture!!
the chap may be talking about the difference between the USDM MR2 turbochargers and the JDM turbochargers the USDM ones have steel shafts. Im pretty sure on the EMS powered forums they were talking about moving to the JDM ones as they have quicker spool up times.
baktasht may be able to shed some light on this
They're very nice.
How vague was that?
If you're talking about the Chinese made copycat turbos, they're complete garbage.
If you're talking about USDM versus JDM OEM CT26/CT20b MR2 turbos, there's a few different ones
USDM steel turbine CT26: Spools the slowest and makes the least power. Maxes out on power around 210-225rwhp with supporting mods. Boost starts to drop off around 4500-5k RPM and drops to around 9-11psi by redline
JDM steel turbine CT26: identical to the one above
JDM ceramic turbine CT26: same compressor as above, spools much faster, and makes more top end power. Can hold boost till redline with a modified wastegate actuator. Maxes out on power around 240-255rwhp with supporting mods
JDM ceramic turbine CT20b: better compressor and turbine design than the CT26. Can hold boost till redline with a modifed wastegate actuator. Maxes out on power around 280-325rwhp with supporting mods.
I've also seen one CT20b with a steel turbine. I'm not sure if this was a rebuild or if Toyota actually made a run of them with steel turbines.
iirc UK Spec ST205 Celica GT4's have steel shafted CT20b's
if you are talking about the JDM cheapo turbos sold on ebay, theres an interesting topic where someone has bought one to see what its like, pretty much for a laugh.
http://www.mr2oc.com/showthread.php?t=332365
Baktash @ EMSPowered wrote:If you're talking about the Chinese made copycat turbos, they're complete garbage.
Bare in mind most of these figures are asuming lots of boost, race gas and increased timing.
Guys on pump gas, sensible boost and stock timing are not hitting those figures over here.
Awwww...for a moment I thought llenrub was back.
