Hi,
I have had a similar problem on another car a few years ago.
Turned out my battery was not holding charge and was losing it whilst my car stood.
A replacement battery solved the issue.
I went to an auto electric specialist and they also checked the alternator as well to verify that it was providing sufficient output to maintain the battery condition and run the systems on the car.
jimGTS wrote:HAPPENED AGAIN PEEPS!!! this time only after not using the car for 1 DAY!!!
been starting fine all the week, using car every day no problems.
any ideas? am charging the battery again, it did try and start early, trying to turn over, just need to charge it a bit more i think.
If you have an alarm fitted then this will slowly drain a battery whilst the car is stood.
If the battery is in poor condition, i.e.
it does not retain charge well, then this slow drain may cause the battery capabilities to drop to a level where it can not provide sufficent charge to turn the engine over and provide power to run the sparks.
jimGTS wrote:since the first time, one of my head light bulbs went, and its taken a week to replace it, could this dead bulb be causing me issues do you think???
ideas welcome.
Unlikely
- but take it to an auto electrician and get them to check everything over.
HTH,
Jon
