can also take 5.5tons!!! pricey at
REALLY should have bought these years ago! i feel so much more comfortable working under the car now.
anyway.
from what i saw, a few random bolts that seem to show the sump has been taken off.
i also found a PHOENIX POWER plaque on the apexi turbo kit downpipe.
im asuming the downpipe is custom made by phoenix power.
plaque read
sw20-345-009"
unfortunatly there was no way of taking a pic of this.
can any confirm or comment on these pics ive taken this evening.
tvsv items removed
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0288.jpg)
gear links bushs!! what make?????
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0290.jpg)
special sump plug?? this is what is feeding my apexi EL1 oil temp gauge
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0293.jpg)
wastegate, anyone know if a certain make?
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0294.jpg)
custom sump fittings for the apexi turbo kit, and ALSO, tapped sump pan to take custom pipe
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0302.jpg)
new ramps
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0306.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0312.jpg)
screamer pipe with custom support bracket to bolt to block
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0313.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0314.jpg)
not sure if stock, if so, what is this area?? bar the obvious gearlink cables
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0317.jpg)
ohlins adjustable damper struts
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0318.jpg)
grex external oil cooler kit of off oil filter.
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0325.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0326.jpg)
brake lines? cant make out the make, anyone recognise??
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0334.jpg)
stock ARB??
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/newRev5/106_0336.jpg)
