[Mk2] [Turbo] Intake temperatures
dave_f
Post by dave_f »
Hi guys, this is one for those of you who have air intake temperature sensors, or have had dyno runs with intake temperature data,
Im after what sort of temps you guys get when boosting. Im ideally looking for some dyno data of a typical run, so an air intake temperature graph. If you could help me out that would be great, also tell me what setup your running, chargecooler, turbo etc.
Cheers guys
steve b
Re: [Mk2] [Turbo] Intake temperatures
Post by steve b »
On which turbo at what boost, makes a big difference.
dave_f
Post by dave_f »
Either ct26 or ct20, stock boost upto maximum safe boost depending on cooling setup.
jimGTS
Post by jimGTS »
steve b wrote:On which turbo at what boost, makes a big difference.
as well as where its taken, and what your using to measure it....
raptor95GTS
Post by raptor95GTS »
rev3 turbo, std intake, std intercooler, 16psi EBC on the road. Just under 80degC under boost, for a er long time WOT
Normally 15degC above ambient cause how long on the road are you actually on boost? I've seen 4degC ;) Was a bloody cold day, also seen 45degC cruise temps which dipped under boost conditions.
Measurement - K Type Thermocouple
position: at throttle plate
accuracy: better than most ;)
steve b
Post by steve b »
allan welsh wrote:rev3 turbo, std intake, std intercooler, 16psi EBC on the road. Just under 80degC under boost, for a er long time WOT
:shock:
Thats HOT.
raptor95GTS
:shock:
Thats HOT.
yup, seen 85degC+ sitting in traffic doing zero mph. Seen 140degC on the dyno, the guy backed off the loud pedal pretty quick lol
On the road though it's not really an issue as I'm never on WOT for any real period of time. :whistle:
greeny
Post by greeny »
allan welsh wrote: Seen 140degC on the dyno, the guy backed off the loud pedal pretty quick lol
I take it it was probably detting its t1ts off?
raptor95GTS
nope it was fine apparently but er power wasn't too good. Oddly enough the next time they paid more attention to the temps.
dave_f
Post by dave_f »
Thanks for the inuput guys, sorry to be so vague but ideally im looking for a dyno graph or figures of air intake temperatures during a dyno run. Or a general idea of what one would look like.
I dont mind whatever setup people have got.
steve b
Post by steve b »
On my mx5 I have bucket loads of log files for AIT whilst on road doing pulls foot to the floor in every gear, but I suspect a big front mount intercooler works better than the MR2 side mount and the turbos a much more efficient item so doesn't heat the air up in the first place.
raptor95GTS
taken on a static dyno so the figures are not the best but you can use it as worse case. T3 is intake temp P3 is boost in psi
later one with mbc
dave_f
Post by dave_f »
thats just the sort of thing im after allan,
any more?
raptor95GTS
nope fair not. Wish I could get one for an on road pull, then you'd see the stock intercooler actually working
