I have been offered 2 set ups
calipers
1 set is off a mr2 with abs.
the other set,
An mr2 without abs
So my quesions are,
1.
2.
3.
Thanks in advance.
madr2turbo wrote:I have a rev1 turbo with the 4x abs pack on it but i would like to upgrade to the bigger rev2/3/4 setup with 275 x 30mm front discs and 281 x 25mm rear.
calipers(4) discs
(4) and pads
(4) at a reasonable price but,
the other set,
An mr2 without abs( the better of the 2 setups
So my quesions are,
1.Can you fit the bigger brake setup from a non abs mr2 turbo to an abs aquiped rev1 mr2 turbo.
2.If the answer is yes, would you lose the use of your abs system.
3.Apart from calipers/discs and pads is there anything else i will need to change/upgrade or modifie when i do the brakes upgrade
Thanks in advance.
