typically cars with front track wider than rear track have a tendency to turn in better, but its so much more complex than that one variable.
giving the MR2 a wider front track wont necessarily fit the stereotype, there are too many other factors at play to make that conclusion without testing it.
i personally dont think youll feel a difference on a road car, there is too much compliance everywhere else to notice such subtle changes.
changing the track by 10mm is unlikely to make much difference
you should currently be 5mm different front to rear, the tyre and wheel widths dont make a difference since the measurement is taken from the centre of the tyre
(and increasing widths will do so in both directions).
offset is the only thing that will change it, as this is measured relative to the vertical wheel centreline, and will position that centreline further in or out.
at the moment your rear track should be 10mm wider than the front
however, as said, camber, castor and toe can all make a significant difference to the measured track width.
personally i wouldnt get too caught up in it, there are better ways to improve turn in characteristics, the first place to start is with dampers!
